I just noticed this. never had any issues with this before?
Tried a couple of times with same results. Fusion 360 stops responding and I have to force quit!
I tried a old model that I have used appearance on before and same thing happens??
I just got a update. could that be it??
I got a new computer a week ago, dont know if I tried appearance on any models on this machine?. however this machine is a couple of times more powerful than my last so that shouldn't be the problem?
What is going on?
Hey @et.teljemo,
I'm sorry to hear that's happening! Can you please give some more details?
Thanks!
If your windows user name has non-ASCII characters this problem occurs. We are working on a fix for this problem and expect to release it as soon as we are able to - likely in the next couple of days. My apologies for the inconvenience, hope to provide an update soon.
Best regards,
Sanjay Jayabal.
I'm in the same situation. When I click "appearance" icon or "A" Fusion 360 stops. And this things happen to me after last update. It's really annoying. I can not change any appearance of my old designs. And I can not add new appearance to my new designs.
Hi @Anonymous,
Really sorry for the disruption, we will be releasing a fix for this very soon (current estimate is sometime next week).
Best regards,
Sanjay Jayabal.
Hi Emanuel,
I am now wondering if this could be something different than the issue we are aware of and in the process of fixing. If your login ID has accented characters for example, the problem shows up when using the appearance command.
One piece of information that would be helpful from all of you that are encountering issues with appearance is - do you get a Crash Error Report dialog when accessing Appearance? Or, does Fusion 360 just become unresponsive and not allow any other interaction? If you do get a Crash Error Report, can you please submit it (and make sure you enter the email ID associated with the account that you were logged in to in Fusion360)? This will help us investigate if there is a different problem.
Best regards,
Sanjay Jayabal.
Whenever i click appearance Fusion 360 stop working. I am facing this issue after update, before it works great. CER not appearing it just close like "This PC" close after hitting close button. i am attaching diagnostic logs. Kindly resolve ASAP.
I also have same issue after last update - even in empty new project when I click Appearance it crashes. In my case it also gives me a chance to send a report, which I did a few times. It's not only appearance but physical material - both do not work. I am having non-ASCII characters in my user name though, so hoping your fix will work for me.
Graphic card: ASUS Geforce GTX 1070 TURBO. OS: Windows 10 PRO
All models that I have tried. Small and big, with or without appearance.
When I click on appearance or hit A (some say materials to, haven't tried that) I never see the appearance window/tool. Fusion freezes before it opens.
Never get that far. fusion freezes before I can even see the tool.
I copied Teljemos answer and changed some that applies for me:
Graphic card: ASUS Geforce GTX 1070 DUAL. OS: Windows 10 HOME
When I click on appearance or hit A, it freezes for like 5 seconds then i get the error report screen
yes i have the same problem too i asked on the facebook groups and i get that answer:(photo 1)
also the other moderators says the same thing i think we will wait
Hey all,
@Anonymous, @et.teljemo, @Anonymous, @Anonymous, @dkorchagin,
A hotfix was just deployed for this issue; you should see it soon!
We have released an update today that should address this issue. Please let us know if you continue to experience the crash after you have updated to our latest version.
We sincerely apologize for the disruption in your work.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
