Fusion 360 Non-linear simulaton
snaMQ3JD
snaMQ3JD
Hi!
How can i view intermediate output in a Fusion 360 Non-linear simulaton if the analysis failes?
e.g. Inventor Nastran allows to tick Intermediate Output = on which enables me to view all the increments up to the failure load. Is this not possible in Fusion 360?
Also, where can i define a custom number of bisections for each increment?
Regards
John_Holtz
Autodesk Support
Autodesk Support
Hi @snaMQ3JD
Here are the answers to your two questions:
  1. It is not possible to view the intermediate results or the partial results of a nonlinear simulation in Fusion. The analysis needs to complete 100% before any results are returned.*
  2. The number of bisections permitted is an input value that is not available to Fusion users.
* Except, the one "result" that is available when the analysis fails is the output file. (Of course, the output file is also available when the analysis is successful.) Right-click on Results in the browser and choose "Solver Data". When the dialog appears, change the option from "Solver Data" to "Solver Output". At a minimum, you can find out how many increments it completed and if there were other warnings or errors that may indicate what caused the problem. For example,
  • If the analysis fails to converge on the first step, it is often due to a piece of the model being close to unstable. Confirm that everything is restricted from moving by constraint or contact. If there is a piece that is questionable, add a constraint to see if that helps get to the first step.
  • If the load increment gets to the point where the model may start yielding, check the material properties. I am not sure where Fusion gets the stress-strain curve, but I often see the stress-strain curve is essentially the same slope as the elastic modulus for a considerable range of stress. I suspect this is hard for the solver to converge and always recommend changing the stress-strain curve.
John
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
shekar_sub
Hi  snaMQ3JD,
 ,> How can i view intermediate output in a Fusion 360 Non-linear simulaton if the analysis failes?
If the Non-linear analysis fails there are no results to view.
If the solve succeeds then one can look at the results at different steps. I have attached an image from the Simulation Samples-> Accuracy Verification Examples -> NonlinearStatic_AVE-01.f3d.
That is not supported. However one can specify the number of steps for the non-linear Simulation under Right Mouse Button on the Study in the browser and Settings.
The other limitations of a Non-Linear static stress study are listed here:https://help.autodesk.com/view/fusion360/ENU/?guid=SIM-NONLIN-STATIC-STRESS are listed here.
If you want one of us to take a look at the model please attach it. We will checkout why it is failing.
Best regards
shekar
jeremy_camper
Hope it's OK I message you
1. I've done a few static simulations but this is my first nonlinear... what faces should I select in this example picture? I guess I don't understand non linear so far?
2. Can you save that animation to a video file?
shekar_sub
Hijeremy_camper,
For your #1, the dataset is available in Home->Samples->Simulation Samples->Accuracy Verification Examples->NonlinearStatic_AVE-01.f3d. You can open this dataset and take a look at how it is setup including which faces are selected. In Simulation workspace you can edit the load Force1 and/or constraint Fixed1.
For #2 I do not see an option to save the animation in this page to a video file. https://help.autodesk.com/view/fusion360/ENU/?guid=SIM-NLSS-HOW-TO-OVERVIEW
Best regards
shekar
