Fusion 360 was functioning just fine until today, now I get the notice that "Fusion 360 is currently offline. ...". My browsers work fine and speedtest tells me my input/output rates are fine. Searching the web I found that several folks attributed this error to C:\Users\kilroy\AppData\Local\Autodesk being defaulted to partially read only - the read-only attributes box in properties is blacked out, not checked ( variously referred to as "folder keeps reverting to read only). I've gone through the recommendations on the web - clear the box, use admin dos command attrib -r +s foldername, change permissions in the security settings - all to no avail. My latest attempt included rolling back one Windows 10 update (no joy) and uninstalling and reinstalling Fusion 360 (still no joy). I'm hoping someone here has solved this.
Solved by ahsan.autodesk. Go to Solution.
Solved by g-andresen. Go to Solution.
Here you go, Fusion360DiagnosticsLogs.zip attached, thanks!
Thanks Gunther,
I did look at Fusion Health at the time and started this answer to reply that that wasn't it. But, thought I'd check before I hit the Post button and to my surprise all is well now (i.e. Fusion 360 and my computer work as before)!
That was the problem, thank you!
Best regards,
DJ
I take it back, it worked for a moment as I was able to load a design file from the cloud, but when I tried to export a .stl file F360/my computer are behaving as they were when I originally posted - "not connected to the internet" - which is not true (as I reply to this thread...).
Can you please do the following:
Hopefully, this will get you going. Please do let me know how it goes.
Yeah, didn't work for me. To say this is a piece of dog crap would be to insult dog crap. Just an infinite time consumption machine.
Hi @Anonymous,
It is quite possible your issue is different from the OP (even though the end effect is the same). If you share your diagnostics files, I can take a look.
i seem to be facing the similar issue as @d.j.taylor.usa .
after looking into this forum, i went into my C: drive and deleted the 2 .xml files.
However, the issue does not seem to be resolved, as after opening Fusion 360, it shows a message
how do i resolve this?
