Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Fusion 360 Hangs During Launch/Startup
0 REPLIES 0
Message 1 of 1
skypilot65
248 Views, 0 Replies
I am experiencing repeated "Program is not responding" issues when trying to launch Fusion 360. The only time I can be reasonably assured it might actually startup and run is after a full system reboot. On the rare occasion it does startup, it runs just fine. Below are my system specs and event viewer application log entries. I've looked for the application logs (using the directions found on this website) following the hang but there doesn't appear to be any from the event. I am running other fairly intensive graphics applications without any issue (CADs, Slicers, Games. etc.). Any help would be greatly appreciated. Thanks.
Kent
System Specs:
Intel I7-6850K CPU @ 3.6Ghz, 128 GB Ram, 2+TB of Disk space
(3) Samsung Displays running at 1920x1080
(2) NVidia GeForce GTX 1080, SLI connected
Windows 10 Pro, version 10.0.18362 Build 18362
Event Viewer Results:
Fault bucket 2036526734779922676, type 5
Event Name: AppHangB1
Response: Not available
Cab Id: 0
Problem signature:
P1: Fusion360.exe
P2: 7824.2.0.0
P3: 5e768b74
P4: a40b
P5: 134217728
P6:
P7:
P8:
P9:
P10:
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER572.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER592.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER591.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER5B1.tmp.txt
\\?\C:\Users\skypi\AppData\Local\Temp\WER3F41.tmp.appcompat.txt
These files may be available here:
\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppHang_Fusion360.exe_5ac07a7b4e4459fc4afc27145b1d2207fda4fc0_fc025829_1d9d94c4-4f35-4602-96d6-68c4590a1119
Analysis symbol:
Rechecking for solution: 0
Report Id: 1f6aaf68-2d11-417f-9ebe-3256986f47cd
Report Status: 268435456
Hashed bucket: ffb86d467b46c0684c4332467a24b8f4
Cab Guid: 0
The program Fusion360.exe version 7824.2.0.0 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Security and Maintenance control panel.
Process ID: 2e60
Start Time: 01d6050e815809ef
Termination Time: 12
Application Path: C:\Users\skypi\AppData\Local\Autodesk\webdeploy\production\edf0a409d74cbc712b7f97f98853d005413e965e\Fusion360.exe
Faulting package full name:
Faulting package-relative application ID:
Hang type: Unknown
Tags (2)
0 REPLIES 0
