I am still very new to Fusion 360 but come from 30+ years on Pro-E and others. I am curious if there is a forum for enhancement ideas that the Fusion team might consider?
Solved by jhackney1972. Go to Solution.
The Fusion 360 Ideas Forum was taken down a long time ago. Your best bet is to post your suggestions on on the Fusion 360 Design, Validate and Document Forum and CLEARLY label in the title that you are posting a Fusion 360 enhancement. You will probably not get a reply but Autodesk developers will probably see it.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
