Running W10-. Downloader begins, stutters around the 2-3% then quits with the following message.
Hi @PTSDAdmin
Where did you download the installer from?
This error message suggests that there may be an issue with the connection or the server that is hosting the Fusion 360 downloader. Here are a few things you can try to resolve the issue:
Make sure your internet connection is stable and that you have a good signal. If you're using a wireless connection, try switching to a wired connection or moving closer to your router.
If you're using a proxy or VPN, try disabling it and see if that resolves the issue.
If none of the above solutions work, you can also try downloading the software from a different device and see if the issue persists.
Try do a manual uninstall of Fusion 360 see if that issue persists.
Have you tried to download F360 through web?
See steps here.
Please make sure that there are no files related to F360 in your Control Panel\Programs\Programs and Features
I'm confused. How do I install Fusion 360 onto a lab computer which will be used by different students?
Gil Brezler
If you are a teacher, you can get hold of F360 support team directly here and explain what are your issue points. They will be able to assist you.
