Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Fusion 360 browser sign in failure
7 REPLIES 7
Message 1 of 8
matejsazama
2427 Views, 7 Replies
I have a problem with logging into Fusion:
When I start the program it takes me to the web sign in prompt, but when I click on "sign-in" the browser doesn't open and the Identity manager reports a crash.
I've tried restarting Fusion and my PC, repairing/reinstalling fusion, changing my default browser to edge, and updating the AdSSO component.
The problem remained unchanged through all of this and I don't know what else to do.
Any help is appreciated.
Thank you very much.
7 REPLIES 7
Message 2 of 8
@matejsazama Can you confirm if you have any other Autodesk products on your machine? There are a couple of other thing we can check on but would like to know if there are other products installed.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 8
Can you also please send us your log files?
1. launch Fusion and while it is launching click on Ctrl+Shift (Window) CMD+Shift (Mac)
2. This will launch the Fusion service utility
3. Gather log files
Please attach the zip file that is generated.
Autodesk Fusion
Join Fusion Insider
Message 4 of 8
The log files are attached.
Also: I don't have any other Autodesk product on my machine.
One more thing: When the Identity Manager crashes, it reports this error: Access violation - code c0000005 (first/second chance not available)
Message 5 of 8
matejsazama
in reply to: matejsazama
Update: I finally caved and factory reset my PC. Afterwards everything worked fine. I don't know if there was some errors in the registry or settings, but hey, it's fixed.
Message 6 of 8
nick_cooper1
When this happens to me I just reinstall Autodesk identity manager and it usually solves the problem. Sometimes it is required to uninstall existing instance version first. This problem crops up far too often tho.
Message 7 of 8
chiduc80
new install fusion 360, but can't sign-in
Message 8 of 8
@chiduc80 What other Autodesk products do you have on your machine?
Autodesk Fusion
Join Fusion Insider
Technology Administrators
