I have a two monitor setup and "Modify" menu window pops up on top right corner of my second monitor (screenshot attached). This shifts my focus and frustrastes me a lot.
Wasn't having this issue before latest patch. Anyone else having this issue? Is there a workaround?
Autodesk Fusion 360 version 2.0.5338
Windows 10 Home version 1803
Edit: this only happens in Sculpt environment.
Thanks for posting! I tested this on my Windows 10 machine today and did not experience the same problem - the drop down menus all showed on the same monitor as Fusion 360.
Does everything work normally if you reset Fusion 360 to its default layout?
How about if you enable the UI preview in your preferences?
I hope this helps! Please let me know if you continue to experience problems.
Hi, @paul.clauss. I suppose it was a conflict with the different resolutions in each monitor, I forgot I had my 2nd monitor with a different resolution - everything is working properly now.
Hugo Pinheiro
