From surface to solid
corradofiorentini
corradofiorentini
Good afternoon. First of all, I apologize for my English and I hope I am in the right section to ask my question.
As per the title of this post I can't find a way to transform this surface into a body with a thickness of 2mm.
I attach the file.
I really hope someone can help me.
Thank you in advance
jeff_strater
The problem is the geometry created by Loft2:
Screenshot 2023-12-03 at 10.18.04 AM.pngScreenshot 2023-12-03 at 10.18.14 AM.png
In this version, I created a 3D sketch and added a couple of rail curves.  I just left them linear, but you can play with the spline handles to get different results.
This produces somewhat nicer geometry:
next, 2mm is REALLY thick for this model.  That depression is not much more than 2mm itself.  I was able to thicken to 2mm, but I'm not sure this is the result you want.  Anyway, you have the info you need, now to work on it on your own.  Use curvature analysis.  Areas of high curvature will always make Thicken fail.
my model is attached
Jeff Strater
Engineering Director
corradofiorentini
Hi Jeff!
Thank you so much for the quick reply!!!
Unfortunately this evening I won't be able to try your advice straight away... I can't wait for the sun to rise!
jhackney1972
It is always nice to direct your Forum replies to the person you are responding to instead of yourself.   When responding to a post from someone, do not use the "Post Reply" icon as this will address your post to yourself. Instead use the "Reply" icon on the post you are responding to address your post to that person. Look back at the messages in this post and you will see what I mean.
John Hackney, Retired
g-andresen
hi,
try this
But you have to make sure that the curves of your sketches are harmonious.
thicken surface.mp4
Video Player is loading.
Current Time 0:00
Duration 3:08
Loaded: 5.27%
Stream Type LIVE
Remaining Time 3:08
1x
    • Chapters
    • descriptions off, selected
    • captions off, selected
    • en (Main), selected
    (view in My Videos)
    günther
    TrippyLighting
    @g-andresen you are correct that the OP should be making sure his curves are "harmonious".
    I observe that your curves aren't harmonious either.
    The code in Fusion 360 (or the geometric modeling kernel, not really sure which) that creates the intersection curve is  inadequate to create smooth curves suitable for creating further geometry. I've provided samples of that to the Fusion 360 team for many, many years!
    The same applies to the offset spline the OP created.
    In fact, Fusion 360 has significant problems to create good lofts, even with better input.
    Instead of offsetting the spline I would offset the surface and then use that for splitting faces or trimming.
    Edit:
    Attached is my version, mostly without curvature issues.
    corradofiorentini
    A thousand thanks
    Type a product name
    ______
    icon-svg-close-thick
    Cookie preferences
    THIRD PARTY SERVICES
    icon-svg-hide-thick
    icon-svg-show-thick
    Qualtrics
    Akamai mPulse
    Digital River
    Dynatrace
    Khoros
    Launch Darkly
    New Relic
    Salesforce Live Agent
    Wistia
    Tealium
    Upsellit
    CJ Affiliates
    Commission Factory
    Typepad Stats
    Geo Targetly
    SpeedCurve
    Qualified
    icon-svg-hide-thick
    icon-svg-show-thick
    Google Optimize
    ClickTale
    OneSignal
    Optimizely
    Amplitude
    Snowplow
    UserVoice
    Clearbit
    YouTube
    icon-svg-hide-thick
    icon-svg-show-thick
    Adobe Analytics
    AdWords
    Marketo
    Doubleclick
    HubSpot
    Twitter
    Facebook
    LinkedIn
    Yahoo! Japan
    Naver
    Quantcast
    Call Tracking
    Wunderkind
    ADC Media
    AgrantSEM
    Bidtellect
    Bing
    G2Crowd
    NMPI Display
    VK
    Adobe Target
    Trendkite
    Hotjar
    6 Sense
    Terminus
    StackAdapt
    The Trade Desk
    RollWorks
    Your experience. Your choice.
