Flat pattern problem: "cuts not coming back to folded geometry"
colin.mcdonald
colin.mcdonald
Hello all:
... I'm not an overly frequent sheet-metal modeller (so shout at me as you will if I'm missing something obvious), but I seem to be getting a repeatable error here.
2.0.9849
Active Plan: Fusion 360, Student
macOS 10.16.0 [edit: strange -- it's MacOS 11.2.2]
Cuts made in the "flat pattern state" are not showing in the folded geometry.
Please see the attached screencast. [edit: nope, it's not coming out of "pending". Two three more discovered errors in one forum post about an error. Nice! Images instead ... not both at once, instead, one ... at ... a ... time!]
Cheers, C
g-andresen
You have to use a different process for that.
Watch the screencast.
günther
colin.mcdonald
Hi Günther:
... Thanks for the reply and for taking the time to make the screencast!
Unfortunately you're doing exactly what I'm doing on this end -- except for a missing command: I cannot access the "refold" step.
  Nonetheless, see the screencast (no sound -- that's not happening in the Mac these days) that goes through the problem after a clean-and-reinstall: https://autode.sk/2Q1SOXW
(Fusion version 2.0.9854 on an iMac, macOS 11.2.2)
Cheers, Colin
g-andresen
if you look at the timeline this is also not possible, because the cut outs are not yet available at this point.
günther
colin.mcdonald
Ah-hah!
  I'm finally catching on here -- use the unfold-refold routine!
  (My memory is going. So soon!)
Cheers, C
