Fusion Support
File Save AS Bug
3 REPLIES 3
381 Views, 3 Replies
File Save AS Bug
When I go to save a file to another project with the SAVE AS, It won't let me select a folder from the project list, it only drags the window around when trying to move the slider.
Tags (1)
3 REPLIES 3
masa.minohara
Hi @Anonymous,
Thank you for posting! I'm not seeing the issue in my environment so I'm not sure if that is a bug. Could you try opening the folder you want to save the design in in the Data Panel, and then saving the file again to see if that allows you to save it at the location you want?
Also, would you be able to record a screencast of the behavior?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
in reply to: masa.minohara
I did try to open the other project and that did not work either. That is the method I tired in the screencast as well.
Jim
masa.minohara
Hi @Anonymous,
Thank you for the screencast! I noticed the design contains inserted components.
Currently saving a design that contains inserted designs in another project is not supported. Please try downloading the file from the web and then uploading it to the project you want.
Please let me know if you have any questions!
Masanobu Minohara
