File limits
File limits
File limits
Before I get excited with Fusion 360 Personal. I would like to know the rules if there is a limit on number of files I can save.
I heard only 10 active files. If so can I delete some to keep it under 10. I don't see a delete option.
I love the software but I can't afford to buy it at this time.
seth.madore
The "10 file limit" applies to active files. When you have 10 files active, you will need to archive one (or more) to un-archive other files. I don't believe there is any expressly stated limit on how many archived files you can have, and I would assume that a limit doesn't exist, or at least, no one has reached it yet.
Seth Madore
jhackney1972
Also keep in mind if you build an assembly, even if it contains 20+ components (not linked components), it counts as one active file.
John Hackney, Retired
seth.madore
Good point, thanks for adding that
Seth Madore
