File Continuously Uploading
jakethomas.email
Message 1 of 11
jakethomas.email
I currently have a file stuck in continuous upload status to the cloud that is slowing down my computer and rendering Fusion unusable. I have posted in several Facebook groups seeking assistance and followed every suggestion given by others. I've clearer the cache, attempted to work offline, uninstalled and reinstalled the program multiple times, even reformatted my entire computer bringing the system back to the day it was purchased. I've had chatGPT walk me through several solutions to no avail.
This issue is not on my computer and I am in need Autodesk supports assistance.
Thanks in advance.
Replies (10)
Message 2 of 11
RajkumarIlanchelian
@jakethomas.email Can you please attach an image of where you are seeing the file stuck?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 11
jakethomas.email
In the file upload dialog box that appears on the left.
Message 4 of 11
RajkumarIlanchelian
@jakethomas.email Can you please try the below?
  • Launch Fusion
  • Go Offline (manual switch)
  • Close Fusion
  • Rename the %APPDATA%\Autodesk\Neutron Platform\Options\<User ID>\login__ActiveDocuments file (OR) \AppData\Roaming\Autodesk\Neutron Platform\Options\<user ID> login__ActiveDocuments file
  • Launch Fusion
  • Editable Document list should be empty
  • Mark a single document editable
  • Go Online
Autodesk Fusion
Join Fusion Insider
Message 5 of 11
jakethomas.email
Thank you for the help through this issue.
I just got back to my computer and followed the steps provided.
The first time I renamed the login__ActiveDocuments file in the App Data , but once I opened the Fusion CAD file I was working on and went back online the problem was there again.
So I followed the steps again this time erasing the login__ActiveDocuments al together and everything seems to be working as it should. Back online and working well.
Thanks again, I truly appreciate the assistance.
Message 6 of 11
sunshinegloria
Community Visitor
Community Visitor
Same issue, but trying to follow the steps and have no idea about the rename app data portion.....can you give details on this step and how?
Message 7 of 11
RajkumarIlanchelian
@sunshinegloria @Did you find the file that we called? You can delete the file. Then do the other steps.
Autodesk Fusion
Join Fusion Insider
Message 8 of 11
sunshinegloria
Community Visitor
Community Visitor
Thanks for the response. I did not find that particular file, but found another and deleted that and that worked....Ill take it. Thanks again...now only to get around the corrupt file loads lol
Message 9 of 11
B_Doerfler
Observer
Observer
Ive deleted the active documents file and the problem still persists. the file keeps coming back after restarting Fusion.
Message 10 of 11
RajkumarIlanchelian
@B_Doerfler Can you please try the below? (Slightly modified than the above)
1. Update to the latest version 2.0.20508 or newer
2. Then run this workflow from the article - https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Files-stuck-in-Edi...
Both of these will ensure that the current problem is fixed and the new version will ensure that customers do not hit the problem again.
Autodesk Fusion
Join Fusion Insider
Message 11 of 11
B_Doerfler
Observer
Observer
Nevermind. I got it to work finally. Thank you for the fix.
