Fusion Support
File cannot be deleted!
5 REPLIES 5
mc_ott
352 Views, 5 Replies
I have a corrupt file that I cannot delete. When I go to the Browser to delete I get the following error: "Cannot delete selected data. Data is in use or relationships exist on selected data." I checked, it has 4 versions and none have any relationship that I can find, also 2 versions don't even show any design in them. Is there some way to forced delete stubborn files? Thanks
5 REPLIES 5
masa.minohara
in reply to: mc_ott
Hi @mc_ott,
Thank you for posting in the forum! Would you mind inviting me to your project so I can find out what's preventing the file from being deleted? My email address is masanobu.minohara@autodesk.com
Also, what are the names of the files that cannot be deleted?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Hi @mc_ott,
Thank you for inviting me to your project! I see a lot of files and folders in your projects.
Which one are you trying to delete?
Masanobu Minohara
mc_ott
in reply to: masa.minohara
The one file I cannot delete is called “To delete” and it has 7 versions, it is in the “RPi Parts” folder, in the “Michel's First Project” project. I have no issues with any other file, just the one I renamed "To delete” is always showing ‘in use’ for some reason.
Michel
masa.minohara
in reply to: mc_ott
Hi @mc_ott,
Thank you for the information! I confirmed that it cannot be deleted and I get the same error message.
Just to check, have you opened this design on another computer? If so, could you try opening this design on that computer and save it as a new version, close the design and Fusion, and then delete the design to see if that makes a difference?
If that doesn't help, I think we will need to check if everything is working correctly at the back end.
Masanobu Minohara
mc_ott
Helo Masa,
Trying your suggestions I get different problem now on my iMac version, it crashes at opening:
I have Fusion 360 on my iMac with Sierra OS on it but does not open, it crashes after starting to open a window in “offline” mode. Gives the following error “Sufficient data not found to switch to Offline mode. Application will go online now.” then crashes. I did 2 installs after complete uninstall using Fusion360_Cleaner app. One install with App-store downloaded app then one from my account at Autodesk download. Both behave the same. I did try to start Fusion 360 from the Terminal.app (going into the package contents of Fusion360 app) and the result is below for your debugging.
I did a complete Fusion360 uninstall again and the app is not on my iMac anymore. Next, I will try my Macbook-Air Fusion360 but I mainly run Fusion360 on my Dell Windows10 laptop because it is faster.
UPDATE:
When I tried Fusion 360 my MacBook, after 5 to 8 minutes, it said something like “Your are working off-line… We are currently updating our services…”. When I try to put it online, it does not go online gives the same message of updating services. There is no way to update the files at present. Below I also included the Terminal.app run results for your debugging.
NOTE:
After today, I will not be able to do anything from my end until the end of this month, I will be away without connection to internet.
Michel
———-Terminal.app results for Fusion 360 on High Sierra Macbook Air —————
Last login: Tue Sep 11 12:11:38 on ttys000
Michels-MacBook-Air:~ michel$ /Applications/Fusion360.app/Contents/MacOS/Fusion360 ; exit;
2018-09-11 12:11:41.046 Fusion360[1947:139608] {"status":"1"}
2018-09-11 12:11:41.202 Fusion360[1947:139608] checking http://itunes.apple.com/CA/lookup?id=868968810 for a new app version...
[2018-09-11 12:11:41.934539] [0x00007fff91ab4380] [info] Config loaded: /Users/michel/Library/Containers/com.autodesk.mas.fusion360/Data/Library/Application Support/Autodesk/Common/Material Library/18072701/adexmtsv_prod.cfg
[2018-09-11 12:11:41.935109] [info]: adexmtsv starts.
[2018-09-11 12:11:41.936472] [info]: Backend is https server.
[2018-09-11 12:11:42.485781] [info]: Start acceptor.
[2018-09-11 12:11:42.486074] [info]: New Pipe Session.
[2018-09-11 12:11:42.543789] [info]: New Pipe Session.
[2018-09-11 12:11:42.647027] [info]: New Pipe Session.
[2018-09-11 12:11:42.694905] [info]: New Pipe Session.
libpng warning: iCCP: known incorrect sRGB profile
[2018-09-11 12:11:43.759362] [info]: New Pipe Session.
RTI initialized. API version: 11.0.2.0
virtual void QSslSocketBackendPrivate::transmit() SSLRead failed with: -9805
2018-09-11 12:13:52.561 Fusion360[1947:139608] *** -[NSAutoreleasePool release]: This pool has already been released, do not drain it (double release).
QObject::connect: No such signal QLineEdit::keyPressEvent(QKeyEvent * event) in /Users/svc_p_bi/Desktop/CI/Jenkins/workspace/lient-delivery_hotfix_18-05-E3S5F4DBXEN56AVFZDJ45O4JCYH7JOCJFG4J67Y7ZB5P3NZ4YWKQ/Core/Neutron/UI/Base/Adaptations/QT/Controls/QTTextCommandControl.cpp:187
QObject::connect: (sender name: 'ctlCommand')
QObject::connect: (receiver name: 'QTTextCommandControl')
QObject::connect: No such signal QPlainTextEdit::keyPressEvent(QKeyEvent * event) in /Users/svc_p_bi/Desktop/CI/Jenkins/workspace/lient-delivery_hotfix_18-05-E3S5F4DBXEN56AVFZDJ45O4JCYH7JOCJFG4J67Y7ZB5P3NZ4YWKQ/Core/Neutron/UI/Base/Adaptations/QT/Controls/QTTextCommandControl.cpp:188
QObject::connect: (sender name: 'ctlResults')
QObject::connect: No such signal QLineEdit::keyReleaseEvent(QKeyEvent * event) in /Users/svc_p_bi/Desktop/CI/Jenkins/workspace/lient-delivery_hotfix_18-05-E3S5F4DBXEN56AVFZDJ45O4JCYH7JOCJFG4J67Y7ZB5P3NZ4YWKQ/Core/Neutron/UI/Base/Adaptations/QT/Controls/QTTextCommandControl.cpp:189
QObject::connect: No such signal QPlainTextEdit::keyReleaseEvent(QKeyEvent * event) in /Users/svc_p_bi/Desktop/CI/Jenkins/workspace/lient-delivery_hotfix_18-05-E3S5F4DBXEN56AVFZDJ45O4JCYH7JOCJFG4J67Y7ZB5P3NZ4YWKQ/Core/Neutron/UI/Base/Adaptations/QT/Controls/QTTextCommandControl.cpp:190
void QCocoaWindow::syncWindowState(Qt::WindowState) invalid window content view size, check your window geometry
[2018-09-11 12:13:55.845974] [info]: New Pipe Session.
QObject: Cannot create children for a parent that is in a different thread.
(Parent is QNetworkAccessManager(0x7ffaafd4f4c0), parent's thread is QThread(0x7ffaa8866b10), current thread is QThread(0x7ffaad1f03a0)
QGLWidget::setContext: Cannot set null context
libpng warning: iCCP: profile 'Photoshop ICC profile': 0h: PCS illuminant is not D50
QWidget::paintEngine: Should no longer be called
QPainter::begin: Paint device returned engine == 0, type: 1
2018-09-11 12:13:58.825 Fusion360[1947:139608] 0x7ffaad26cb60=""> received webView:windowScriptObjectAvailable:
2018-09-11 12:13:58.827 Fusion360[1947:139608] 0x7ffaafc844d0=""> received webView:windowScriptObjectAvailable:
2018-09-11 12:13:58.833 Fusion360[1947:139608] 0x7ffab2b3e890=""> received webView:windowScriptObjectAvailable:
2018-09-11 12:13:58.834 Fusion360[1947:139608] 0x7ffab2c492c0=""> received webView:windowScriptObjectAvailable:
QLayout: Attempting to add QLayout "" to Nu::QTJobManagerDlg "JobManagerDlg", which already has a layout
2018-09-11 12:13:59.769 Fusion360[1947:139608] checking http://itunes.apple.com/CA/lookup?id=868968810 for a new app version...
2018-09-11 12:18:02.480 Fusion360[1947:157492] CFNetwork SSLHandshake failed (-9807)
2018-09-11 12:19:03.629 Fusion360[1947:139608] 0x7ffab2b3e890=""> received webView:windowScriptObjectAvailable:
2018-09-11 12:19:04.526 Fusion360[1947:139608] 0x7ffab2c492c0=""> received webView:windowScriptObjectAvailable:
QLayout: Attempting to add QLayout "" to QTFusionUpdateControl "", which already has a layout
QLayout: Attempting to add QLayout "" to QTTeamHubControl "", which already has a layout
2018-09-11 12:19:42.074 Fusion360[1947:165852] checking http://itunes.apple.com/CA/lookup?id=868968810 for a new app version...
2018-09-11 12:22:13.865 Fusion360[1947:175547] checking http://itunes.apple.com/CA/lookup?id=868968810 for a new app version...
2018-09-11 12:23:45.833 Fusion360[1947:179855] checking http://itunes.apple.com/CA/lookup?id=868968810 for a new app version...
————— Terminal Run Fusion 360 on my iMac with Sierra OS ————-
MC-iMac27:~ michel$ /Applications/Fusion360.app/Contents/MacOS/Fusion360 ; exit;
2018-09-11 10:42:03.943 Fusion360[22764:17077308] {"status":"1"}
2018-09-11 10:42:04.115 Fusion360[22764:17077308] checking http://itunes.apple.com/CA/lookup?id=868968810 for a new app version...
[2018-09-11 10:42:04.731418] [0x00007fffc5f083c0] [info] Config loaded: /Volumes/Drobo3GB/michel/Library/Containers/com.autodesk.mas.fusion360/Data/Library/Application Support/Autodesk/Common/Material Library/18072701/adexmtsv_prod.cfg
[2018-09-11 10:42:04.732207] [info]: adexmtsv starts.
[2018-09-11 10:42:04.733646] [info]: Backend is https server.
[2018-09-11 10:42:04.978560] [info]: Start acceptor.
[2018-09-11 10:42:04.978776] [info]: New Pipe Session.
[2018-09-11 10:42:05.043958] [info]: New Pipe Session.
[2018-09-11 10:42:05.176243] [info]: New Pipe Session.
[2018-09-11 10:42:05.222863] [info]: New Pipe Session.
[2018-09-11 10:42:06.429988] [info]: New Pipe Session.
1536676934 src/json.c:1001: Error err_reason_fromjson: '[' or '{' expected near '<'
2018-09-11 10:42:15.140 Fusion360[22764:17077308] *** -[NSAutoreleasePool release]: This pool has already been released, do not drain it (double release).
[2018-09-11 10:42:18.081965] [info]: New Pipe Session.
(Parent is QNetworkAccessManager(0x7fab72eebed0), parent's thread is QThread(0x7fab6999da60), current thread is QThread(0x7fab76103680)
2018-09-11 10:42:21.661 Fusion360[22764:17077308] 0x7fab76112b30=""> received webView:windowScriptObjectAvailable:
2018-09-11 10:42:21.665 Fusion360[22764:17077308] 0x7fab7608bdd0=""> received webView:windowScriptObjectAvailable:
2018-09-11 10:42:21.668 Fusion360[22764:17077308] 0x7fab75b61fe0=""> received webView:windowScriptObjectAvailable:
2018-09-11 10:42:22.339 Fusion360[22764:17077308] checking http://itunes.apple.com/CA/lookup?id=868968810 for a new app version...
2018-09-11 10:42:22.505 Fusion360[22764:17081736] CFNetwork SSLHandshake failed (-9807)
2018-09-11 10:42:23.161 Fusion360[22764:17077308] 0x7fab75b61fe0=""> received webView:windowScriptObjectAvailable:
1536676950 src/json.c:1001: Error err_reason_fromjson: '[' or '{' expected near '<'
[2018-09-11 10:42:34.932035] [info]: adexmtsv stopped.
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
Deleting expired sessions…4 completed.
[Process completed]
