Just installed the latest main-channel update of Fusion (V.2.0.15509). During the update Fusion asks for access to modify apps and programs on my system. This has not happened before, so what changed?
Solved by RajkumarIlanchelian. Go to Solution.
@schack.lindemann @Nothing changed on the Fusion side. This is the latest security that Apple applied to their macOS update.
The message from Apple is generic that it sounds like this is going to modify all other programs where as it is not the case. If you go into Apple security you will see this is the common message they have in there.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
