Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Feature not following path correctly (pattern along path)
2 REPLIES 2
ralliartswe
760 Views, 2 Replies
Using Pattern along path yields some unwelcome results. I'm selecting an extrusion (feature) that I wanto pattern along a centerline of a wall. The wall goes is a Z shape of two 45 degree angle turns. At these turns the pattern overshoots and won't stay on the intended path.
Tried with different compute options and path orientations.
Attaching f3d file, and youtube link of screencast.
2 REPLIES 2
davebYYPCU
in reply to: ralliartswe
Feature is Not at start point of the Path, (0.00)
measure the distance to feature as percentage of the path.
Might help.....
ralliartswe
in reply to: davebYYPCU
Sweet! It worked! Thank you.
Best regards,
Erik
