Hi
I have open . skp files in F360 for converting to solidworks format like .iges.
But all the exported files are blank.
What I'm doing wrong?
I heve try another skp file, larger, but the only result is that the iges exported files are 20 to 100k. And imported in SW or back to F360, nothing appear.
The skp imported files are ok, looks good and divided in components. I have try to export only a component, or entire model, the same result.
Thank you
I'd guess the mesh is not supported in the translation. Have you tried converting the mesh to a Brep in Fusion first?
Mark
Mark Hughes
Owner, Hughes Tooling
I heve read about this problem, but as a test, I create a simple cube in skp, and import it in F360. The same problem. No mesh was applied. Or F360 maybe see the colour of the imported model as a mesh. I will try your solution. Thank you
