Hi all,
When i launch my F360 i got a "Sufficient data not found to switch to offline mode in Fusion 360" error, so i first tried this with no luck.
Then tried clean reinstall as suggested by @masa.minohar explained here.
And now i'm stuck with a "host is down" message for the url:dl.appstreaming.autotdesk.com/production/(...)/full.json. Obviously my internet is ok otherwise i would'nt post here.
Any idea, because right now i just can't work with Fusion... ?
Thx,
Odo
Solved by odolyte. Go to Solution.
Since the 5th dec update a few people have been having problems, including me. My resolution came from another thread. I had to run through a sequence (winsock reset, Automatic clean uninstall for Autodesk Fusion 360 and reinstall) corrected the problem.
The other thread can be found here
Hope this gets you back up and running.
Best,
MarkCK
Hi @MarkCK_NL Thanks for your help !
I've tried to reinstall with a VPN connection from sweden and the install reloaded and worked.
Then i connected with my normal connection. I think that the problem may have occured on Autodesk servers since i didn't experience other issues with my internet connection.
Everything's fine now.
Thanks again
Odo
