Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Exporting to NC program errors. I am stumped...
2 REPLIES 2
RonaldGIII
135 Views, 2 Replies
I have spent hours looking over everything and cannot seem to find the source of my errors, if anyone could help me I would be so thankful. Below are the errors as well as the shared file.. I am trying to mill out that pocket for a grease groove on a part that everything else machined fine..
Error: Direction is not supported for machine configuration.
Error at line: 2382 (haas next generation.cps)
Error in operation: '2D Pocket2'
https://a360.co/4cOfu2A
Tags (2)
2 REPLIES 2
a.laasW8M6T
in reply to: RonaldGIII
Hi
You are using tool orientation to set the machining direction flipped from your setup orientation:
being that this is probably on a 3 axis machine this isn't the correct way to do it. you need to have the setup orientation correct and don't use tool orientation
Change the orientation to "select Z and X axis"
RonaldGIII
in reply to: a.laasW8M6T
Ohh my gosh, you are a life saver. I don't know why I couldn't figure that out, too much going on at work I guess when I was trying to finish that.
Thank you so much for taking the time to help me out, I greatly appreciate it.
