Export 3D DWG/DXF Failing
I am trying to export a 3D DXF/DWG file and am having much difficulty exporting the file. I brought the file from AutoCAD 3D and am trying to work it in Fusion then export a 3D file for a programming software. The problem is it requires a 3D DWG or DXF file and I am running into an export issue. Whenever I try to export a DWG file it says "Export Failed" with no additional anything. Same goes for a DXF file. "Export Failed". It's every file I try to export even through the dashboard and Fusion it fails the export.
I am in need of help on this as it makes no sense as I did it no problem with another file however now I am unable to export anything.
