Fusion Support
expired subscription
1 REPLY 1
1316 Views, 1 Reply
What happens with the projects once Fusion 360 subscription expires?
Is it any easy way to download all projects files on local HD?
Thank you
1 REPLY 1
mike.tessier
Hi @Anonymous,
Thanks for posting!
You should still have access to the designs through Fusion and myhub.autodesk360.com for some time to gather and backup your data, but you won't be able to make modifications to designs or create new designs. See the Terms of Service for more information on how your data is handled by Autodesk. There are some tricks we can use to bulk download the designs, however there is no easy way to download them all at once and keep your project hierarchy intact.
The easiest way to download multiple designs at one time is going to be by creating folders within your project to house the design files. Once you get the designs into a folder within the project, the folder can be downloaded from A360. To do this, navigate to myhub.autodesk360.com and sign into your account. Once you get signed in, navigate to the first project that you would like to download and click into it. Once you are within the project, click the "New" icon and select "Folder" from the drop down menu. Once the folder is created, you can move your designs into the folder by hovering over the design you want to move, clicking the downwards pointing carrot and selecting "Move" from the drop down menu.
Once you get all of your designs into a folder (I would recommend one folder per project), the folder can be downloaded by clicking the downwards pointing arrow.
I hope this helps! Please let me know if you have any questions or concerns - I am always happy to lend a hand!
Cheers,
Mike Tessier
Product Support Specialist
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Technology Administrators
