Error: Split2 Compute Failed No intersection between target(s) and split tool
I've been trying to get a split body to work for a simple shape and I've tried so many ways to split the body with two surfaces but it always fails. If I select one surface and use extend, it is able to slice the body, but when I include both surfaces, I get the error. I was able to get the body split by splitting each face and then stitching all the faces up to create a solid body.
It seems like the split body should work, but I can't find information as to what the error is complaining about. Any help would be appreciated.
I've included the file, to replicate the problem, select the Body1 and under Solid->Modify->Split Body. Select Body(3) and Body(4) as the splitting Tools, select Extend Splitting Tool and press Ok, then you'll get the error.
Cheers
Michael
