Error: Split2 Compute Failed No intersection between target(s) and split tool
mbonadio
mbonadio
I've been trying to get a split body to work for a simple shape and I've tried so many ways to split the body with two surfaces but it always fails. If I select one surface and use extend, it is able to slice the body, but when I include both surfaces, I get the error. I was able to get the body split by splitting each face and then stitching all the faces up to create a solid body.
It seems like the split body should work, but I can't find information as to what the error is complaining about. Any help would be appreciated.
I've included the file, to replicate the problem, select the Body1 and under Solid->Modify->Split Body. Select Body(3) and Body(4) as the splitting Tools, select Extend Splitting Tool and press Ok, then you'll get the error.
Cheers
Michael
davebYYPCU
Your process will work one at a time, as a workaround,
Split the cylinder into 2 first with XZ plane
Split front body with body 3
Split rear body with body 4
Combine the two left hand bodies and then the 2 right hand bodies.
Pics with the timeline marker will demo.
mbonadio
Thanks Dave for the work around, I appreciate the effort you went through to document it. I found a work around by using split faces instead of split bodies, what I can't understand is why the split body doesn't work when by all circumstance it should, it seems like a bug to me which was why I created the post.
It seems to me that it should work, and I tried many different variations of the cutting surface and I couldn't get it to slice correctly.
There doesn't seem to be a way to diagnose what the issue is and therefore no way to make it function correctly.
Michael
davebYYPCU
I think it is that - attempting to cut one body with 2 cutters to result in 2 bodies.
If you use a single cutter for the result it will work,
(Lofted the inside edges of the two cutters and stitched.)
Limitation not a bug.
mbonadio
My original design had 3 surfaces that I had wanted to use as a cutting tool, I took it down to get to a simpler version with just two surfaces to cut through the body. Would the suggestion be to create 3 planes so that you can use a single cutter?
Michael
davebYYPCU
Planes - or cutter surfaces, I believe your limits are getting exasperated by cutting a cylinder, so cuts have to penetrate the walls twice.  Split body needs the result of additional bodies.
You may need one body patterned
Might help...
