Hi
Im modelling a simple 2 axis solar tracker one axis works but the horizontal dont work. I aligned the revolve with between 2 plates option, but when Im aligning on the frame (see files) theres a error "compute error" and check the joints, contacts sets. But it doesnt say more than that and Ive no other joint warnings. I tried using Circular to see if there was a difference between the 2 mounting plates but it says 0mm, but when I try change it to revolve it doesnt work
