Error on Multi-Axis Post Processor : onLinear5D's param feed is zero!
i test a Multi-Axis example,it looks good!but when i post it,something wrong happened.
when f360 call post function onLinear5D, param feed is 0.so,it can't be make a nc code .
I am confused and don't know what went wrong!please help me,thanks!
here is detail:1.png2.png3.png4.png5.png6.png7.png8.png
will_1
Hi @Anonymous ,
If you send your fusion file so I can duplicate the issue I can take a look.
Will
here is my fusion project link:https://a360.co/342sTm4
and please download post process file from:GRBL Multi-Axis Post Processor
thanks!
will_1
Hi @Anonymous ,
It looks like "highFeedRate" needs to be defined in the post processor.
minimumChordLength = spatial(0.25MM);
minimumCircularRadius = spatial(0.01MM);
maximumCircularRadius = spatial(1000MM);
minimumCircularSweep = toRad(0.01);
maximumCircularSweep = toRad(180);
allowHelicalMoves = true;
allowedCircularPlanes = undefined// allow any circular motion
highFeedrate = (unit == IN) ? 650 : 5000//
Add it at the beginning where you see this code. You may need to adjust the values for your machine.
Will
It's works,Thank you so much!
