Emboss tool problems
kylejames97
kylejames97
I'm trying to deboss the panel details into my model, but I'm having some difficulties. Firstly, when I try to select the two faces I want the deboss, it tells me I straight up can't do it. There was originally a fillet to remove the hard edge, but it seems the emboss tool doesn't work with fillets at all.
And secondly, when I tried to deboss the two surfaces individually, it doesn't fill the entire face with the line I'm trying to add.
If anyone has any ideas, I'd be happy to try. Otherwise I'll just make some extrusions and use the cut tool to add the recessed areas, or some 0-thickness panels and the cut tool, and the fillet to curve the cut lines.
davebYYPCU
Emboss Tool is not configured for faces with compound curves.
Might help....
