360 states that my email is not verified. I continue to log in receive a text with the code, re-enter code with no fix.
Hi there,
Please double check that your email is associated with an Autodesk account that has either an educational or paid license for Fusion 360. Check your spam folders for the verification email, and also whitelist the Autodesk email accounts.
If this solved your problem, please select "Accept as Solution" so others can find the answer to a similar problem. Thanks and Good Luck!
Cole
Also, try logging into an Autodesk website, and making sure your account is fully setup. This may attribute to your problem.
