DXF import coming in flipped or rotated 180º
I have a simple curve I've created in Illustrator, exported as a DXF that I'm trying to add to a sketch. When I insert the DXF in Fusion, it shows rotated 180º.
If I look at the same DXF in the Autodesk online viewer, it appears correctly.
Unlike the SVG tool (which has its own myriad usability problems) you can't rotate the DXF on import, so I guess I'm left pre-rotating it in Illustrator? Is there a reason it's doing this or is it a bug?
Link copied
