I have made an arrangement to for cabinets that I am building and I have extra space on my plywood structure. I do not understand how I can make copies of some of the parts to fill the entire structure as I do not have any options to create copies? I noticed Create Copies is checked but greyed out. Any ideas? Just learning Fusion.
Solved by seth.madore. Go to Solution.
As far as I understand, we don't currently support Copies when XREF components are involved; is that the case with this file?
So if I understand correctly, I would need to set up a new arrangement to fill this extra space?
Would you be able to share your Fusion file(s) here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Hi Seth, I sure will. I did get inContact with fusion and they said it couldn't be done and then someone else said that you could copy and paste somehow but I really don't know how that works as I cannot get it to do this. This is a complete base cabinet that I would like to fill up as m
Ah, I just noticed that you don't have the Machining Extension. No, automatically creating copies is not possible without the extension. You would have to manually create duplicates of the parts you want to Arrange.
