Since updating to 2.0.5966 (Mac) Fusion 360, my drawing templates have stopped working, both in creating a new drawing and trying to select drawing templates (see screenshot) - the templates do not appear after update, and in trying to create new drawing templates (see attached screenshot - save as template missing in output and save as, but can save through - file - new drawing - drawing template, however these still do not appear in the create new drawing template menu).
My previous templates are still saved and present but do not link to the create drawing template dialogue.
I believe this is a bug, and will hopefully be corrected in an update. Is anybody else experiencing the same issues / is there a quick fix/ get around to re-direct the drawing creation tool window to the drawing templates saved?
Many Thanks.
Hello @Anonymous
This certainly a strange behavior. Would you be able to attach the template file to this post so that we can try to debug the issue? If you don't wish to post the files here you can send them to my work email id rohit.bapat@autodesk.com
Just a few questions for my understanding..
Are you able to open the template file individually? Also, can you please try opening and saving the template again if you can?
Thank you,
Best Regards
Rohit Bapat
(Product Owner, Fusion 360)
Hello @rohit.bapat
Thanks for replying so quickly, I've since reinstalled and it solved the problem!
If it helps preventing the same bug for others, I could open the drawing template files individually, where they were displaying correctly as drawing template files, but I couldn't save them for some reason.
Best,
Max
