Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Drawing: Dimensions between centers of arcs
4 REPLIES 4
fsonnichsen
189 Views, 4 Replies
I have two closely spaced arcs (see drawing/pdf) and I want to label the distance between centers. I can display the distance of the edges---17mm in this case---but I cannot distance the centers. The dimension tool implies that this can be done but I cannot seem to click on the centers.
Any thoughts?
thanks
Fritz
4 REPLIES 4
ClintBrown3D
in reply to: fsonnichsen
Hi @fsonnichsen
Please can you share the drawing with us to have a look at? Have you tried using object snaps (right click >Center), or trying to place centre marks on the arcs?
hamid.sh.
I used your design file from here, edited it to match the above visually (i.e. sweeps not ending at the same point) and made this drawing:
Works OK for me, didn't have any problem snapping dimension tool to centers. Note that it appears while you hover the mouse pointer on circles' edge.
Hamid
ClintBrown3D
in reply to: ClintBrown3D
Hi @fsonnichsen
As @hamid.sh. says you should be able to dimension that geometry with no problem.
If you are having trouble, try the snaps that I mentioned above, this should help.
fsonnichsen
Sorry-I was away for a bit --thanks both of you-- It is working now. Here are some comments
1) Normally I  EXPORT an f3d for designs . I sent the PDF for the drawing because I don't see a way to export it.
2) At first the dimension did not work so I was using the "Linear dimension" and the "radius" neither which seemed to work. Going back to the regular "dimension" command it works now--just a bit finicky in this case.
cheers
Fritz
