I have a design where I changed several dimensions. All but one update correctly to the linked drawings except the depth (it was changed from 0.745 to 0.748. Creating a new drawing still reflects 0.745. At first, I thought it was a rotation problem but extrusions show 0 angle and the old value of 0.745 should have shown differently if the object was rotated. As a check, I did a sketch top view in the design, created a vertical line with the starting point horizontal to one corner and made it 0.748 long and forced it vertical. lines between the two corners of the object and the two end points of the line are the same length and zero angle. I must be doing something wrong in the design that is causing this error, a constraint or something but I can not see it.
I shared the file in the autodesk gallery with the name "Block with Dimension that does not update in drawing".
Any help would be appreciated.
Thanks!
Ken
