Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Drawing Detail View Empty / Misaligned
3 REPLIES 3
euclidmandd
403 Views, 3 Replies
Hi, I'm starting to have issued with detailed views in some drawings.  At first I thought the views were totally empty, but eventually I realized they're just not aligned properly.  As the picture shows, view D is well off to the left of the parent view and is not accurately displaying what's inside the circle.  I've seen some similar post, including here where's it mentioned in passing, but no real responses or work-arounds that I've found.  Also, this error is present on the exported PDF.
It seems to be pretty random.  I started a new drawing and 2 detail views worked on page 1, and then a couple pages later I'm having this issue again.  It also seems to be related to the new page, or view because I can go back to page 1 and 2 and the detail views work fine.  It's happened in 2 drawings so far both in the same project.  I'll update this if I find any sort of pattern or fix.
Running on Windows
3 REPLIES 3
masa.minohara
in reply to: euclidmandd
Hi @euclidmandd ,
Thank you for posting about the issue! Would it be possible for you to share a public link to the drawing that contains the issue with me so I can test?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
euclidmandd
in reply to: masa.minohara
Sure.  Here's the drawing:
https://a360.co/2UBvEIG
And here's the model it's referencing if needed:
https://a360.co/2UpwTKH
FYI, I kind of just fiddled around with it for a while (deleting detailed views that didn't work or trying them on different parent views) and eventually I got it to work.  I also tried opening the file right now, and it didn't seem to have the issue anymore.
masa.minohara
Hi @euclidmandd ,
Thank you for sharing the files with me! As you mentioned, the issue seems to have solved in that drawing and I was not able to see the issue.
I'll try to reproduce the issue with this, but if you find a way to reproduce it, please let me know. That would be very helpful for us to troubleshoot further.
Masanobu Minohara
