i have Dpi issue after last update. Before update was everythings OK.
My laptop HP Z-book 14
Resolution: 1920x1080
Dpi set to default: 150
This steps not working for me:
Now are all items,icons big and displayed blury and
Thank you!
On second PC in office same issue 😞 , tried everything include total clean reinstall .... Why autodesk send unstable updates to the word ??? I need work fusion for work not for playing 😞 Hope someone from Autodesk team fix it asap.
I have the same problem, only helps to set the DPI to 100%, but then it is not convenient to use Windows.
Same problem here, did anybody found a solution or are we waiting for Autodesk to fix it in the next update ?
Thanks for reporting this issue to us!
In the latest Fusion update, there's a fix to address the blur issue caused by system DPI change. But need apply the workaround as below:
Let me know if this still doesn't work for you after upgrading into the latest Fusion update and turn on above workaround.
-Lisa
