Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Does anyone know why I cant flatten this part?
7 REPLIES 7
Message 1 of 8
ParametricScenicXYZ
324 Views, 7 Replies
Hello! I hope you are all well.
Does anyone know why I cant flatten the item Beacon Band v1. I have modelled it in the other file and thought I had done it in such a way it would work! Perfectly even throughout.
Any advice gratefully received.
Many thanks
7 REPLIES 7
Message 2 of 8
Please attach the F3D file.
John Hackney, Retired
Message 3 of 8
Thank you for looking!
Message 4 of 8
Cut edges not perpendicular to the face.
Also - unconstrained and overly complex sketches.
Need make only one Component and Pattern Components for the slats.
Message 5 of 8
Thank you I shall look to correct !
Message 6 of 8
@ParametricScenicXYZ
I would not have marked as solution until you figure out the solution.
No workplanes other than the Origin planes are needed for this design.
I would not use Loft.
Cannot have compound curvature. (Would have to export to MeshMixer or Autodesk Inventor Professional to Unwrap).
How will you manufacture the compound curvature? (For this design you could probably get away with modeling extrudes/Trimmed surfaces/Thicken and be close enough.)
Again - consider that all slats are the same.
So sketch and model for only one - convert to Component and Pattern Component.
This entire design can be made from two very simple sketches (you will need to give information about manufacture of the compound curvature).
Or use @jhackney1972 solution.
Message 7 of 8
Your model has some thickness irregularities but this is what I came up with for a flat layout.  Model is attached.
Message 8 of 8
This awesome thank you! - I will follow the steps myself to get the same result!
