I am encountering a problem where changing a dimension in a sketch is accepted, but not processed. There is no feedback or indication that the action is not being performed. The usual "restarting the software when encountering a bug" does not solve it. Not receiving feedback that this was happening, this bug has resulted in the production of the part without the required tolerance corrections, costing me time and resources... In the attached images, the problem with a driven, identical dimension can clearly be seen.
Update: I am able to have the dimension update to the entered value when changing a different dimension in the sketch and then changing it back. However, this still needs to be resolved ASAP, as I currently cannot rely on the software.
Hereby the simplified design file. Changing d1 to another value usually does not result in the sketch updating. Sometimes it does update, but so far I have not been able to find a direct cause for this.
