Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
desing is transparent and i cant make it filled again
2 REPLIES 2
temujar
161 Views, 2 Replies
temujar
Observer
Observer
i desinged a piece and everything was ok in the start, but when i decided to try out a button command ctrl+/ the desing went transparent and i cant return it to the way it was. I have tried turning the opacity and the active component visibility but nothing helps. Is there just some command or tab i need to check?
2 REPLIES 2
g-andresen
in reply to: temujar
g-andresen
check your display setting
günther
günther
temujar
in reply to: g-andresen
temujar
Observer
Observer
Thank you so much!, i have learned by myself to use fusion and this was first time this happened and i was getting desperate to get the design as it was.
