Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Design History Moved to Tree
1 REPLY 1
skylerbagley21
134 Views, 1 Reply
I'm not sure what the proper name for it is, but my "design history" (the one that shows what I've extruded, or chamfered, etc.) is now under my sketches in the tree instead of across the bottom of the window. I'm guessing this was probably something with the latest update. Is there any way I can move it back to the bottom of the window?
Tags (2)
Labels (2)
1 REPLY 1
You are in direct mode. Did you disable history or are you working on an imported part?
You can enable Capture Design History from the right click menu from the top folder in the browser.
Mark Hughes
Owner, Hughes Tooling
Technology Administrators
