Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Derive references within the same hub -- nothing changed but can't insert
6 REPLIES 6
1081 Views, 6 Replies
Nothing changed at all (just had an issue where F360 said it was working in offline mode due to maintenance) but now I can't insert via derive into my designs any more -- everything is in the same folder and I'm going through the same process as I had been all day... Any suggestions?
6 REPLIES 6
masa.minohara
Hi @Anonymous ,
Is your computer connected to the internet? Could you try switching to online mode to see if that helps?
If that doesn't help, could you attach a screenshot of what you are seeing?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
in reply to: masa.minohara
I was able to sidestep the issue with right-selecting a new design with only the element I'm trying to insert and clicking "insert into design", but the general issue isn't fixed. Screenshots below
masa.minohara
Hi @Anonymous ,
Thank you for the screenshot! Which design did you try to insert? Is that design saved within "My First Project"?
Would you mind attaching the diagnostic log files?
Masanobu Minohara
I only have designs in the "my first project" project. Logs attached
masa.minohara
Hi @Anonymous ,
Thank you for attaching the diagnostic log files! I'll take a look at it and post an update as soon as I have one.
In the meantime, would you mind trying the items below to see if you can work around the issue?
  • Use "Save as" command to create a new design, and try inserting Derive using the newly saved design
  • Use Export command to save the file locally, and upload it to your project. Then, insert Derive using the uploaded file
Masanobu Minohara
I already found a workaround using the insert a design feature from the browser, thank you!
Technology Administrators
