I'm new to Fusion 360. I have problem with data panel. It shows black window there (see attached snapshot). However, first time I used it, it worked fine. But somehow it quits working. I tried rebooting my computer and reinstall Fusion. Neither helps.
Thank you very much!
Hi Ben,
We got a laptop machine and reproduced this blcak data panel issue. After some investigation, we found that if we go to the Windows device manager and then disable Intel GPU, this issue is gone. So probably you can try the same thing on your side to see if this works for you as well.
Chengyun
Fusion Development Team.
Hi chengyun.yang,
I tried disabling the intel process and the issue went away. Unfortunately, I kept receiving graphics errors/warnings though and I could no longer use multiple displays.
-Phil
Hi Baribak,
I have tried everything and it did not seem to help. When I did force the intel graphics off per chengyun.yang's recommendation the issue did resolve put caused other problems. I have attached a log file though so that you can take a look at what is happening with the error. From what I can tell there isn't going to be an easy fix for me. I can deal with the issue for the time being until an an actual fix is found.
That is unfortunate. I will bring it to our data panel team to see if they can make the data panel browser to work with the Intel GPU however this may take some time.
-Chengyun
One internal bug UP-27274 is created to track this issue. To fix this issue, it may involve upgrading the embeded chrome browser to a new version so it could take some time.
I am not sure how Adobe works around this(probably they directly talk to GPU driver instead of through some official 3D APIs) but the below is the message we got directly from AMD developers:
Hey,
I have found one more workaround for this problem, without changing anything in BIOS or disabling default graphics card. Where shall i post the solution?? I see that there are multiple posts about the same black panel issue. Is there any way you can help me post this?
Its not a complete fix but i guess your engineering team can find a solution through this.
Hi syedmahin1991,
Please feel free to share any info here on the forum. Your fellow users and those working on Fusion would greatly appreciate any additional info you can provide regarding this problem.
Thanks for the quick reply.
I use Dell inspiron with windows 8.1, I use fusion 360 in my office PC & it runs perfectly. When i use it on my laptop it was giving the same black data panel problem. I searched for solution in forums but none of the solution worked out for me. I tried disabling intel graphics card, updating bios & other recommended solutions but nothing worked out. Finally, when i did following it worked.
1.Right click on fusion 360 icon on desktop
2.Click troubleshoot compatibility
3.'program compatibility troubleshooter' opens, I select the option 'Try recommended settings'
4.It says: Settings applied to fusion launcher: windows compatibility mode: Windows 8
5.when i click the 'Test the program...' button, Fusion 360 launches with perfectly working Data panel.
Everything works fine and program runs using secondary graphics card, it doesn't show in 'Graphics Diagnostics' but i know it uses it as i tested with complex structures and it was running smooth.
But here the problem is i have to follow the above 5 steps every time i use Fusion 360. But it takes hardly 5 seconds to do it, so i am using it from over a month now.
I thought engineers at autodesk can find a solution for this problem so i decided to post this on forum.
Unofficial: Frankly i love fusion 360 from the core of my heart. I have recommended this application to solidworks & nx users. I even sometimes keep a competition with my colleague who uses solidworks just to see who can develop a component faster. But when i found out this problem in laptop i was very sad. I really want fusion to solve it soon & shine forever.
Hi, I have been trying all suggestion I found in the internet, even contact Autodesk via email.
The problem is after all communication, I dont have the specific time to sit and share the screen as required.
It was working before, flawlessly, and suddenly data panel and the small panel beside went black.
Please kindly check, if many of us here having the same issue where it was working before, I might think that something has been change with Fusion software itself, or?
It was a good program though
Hi garorica,
Can you try renaming the files NMachineSpecificOptions.xml and NGlobalOptions.xml and see if it helps? They're located in:
(First, exit Fusion.)
Windows:
C:\Users\<username>\AppData\Roaming\Autodesk\Neutron Platform\Options
C:\Users\<username>\AppData\Roaming\Autodesk\Neutron Platform\Options\{alphanumericfoldername}
OSX:
/users/<username>/library//application support/autodesk/neutron platform/options
/users/<username>/library//application support/autodesk/neutron platform/options/{alphanumericfoldername}
Once done, launch Fusion.
I am having this kind of thing, and it locks my fusion, so I have to restart it.
But I think I found some relation to it happening every time I try to offset some cylindrical faces that have some hole with treads entering in them, I don't know if any of these can be of any help but for it seems that it is whats happening to me.
I have the same black data panel problem on an Intel HD graphics based laptop. On my machine, I found that it has something to do with the power management mode.
If I start Fusion 360 while the power is unplugged it works fine.
If I start Fusion 360 while the power adapter is plugged in I get the black data panel.
The laptop is an HP EliteBook 840. I have tried several different power management settings, but I could not get it to work properly.
I had the same problem.
My laptop is HP pavilion DV6 also on an Intel HD graphics based laptop.
The post of Daveplant solved the problem.
If i start Fusion 360 unplugged everything is fine.
I just realised that if you start fusion 360 in recommended power option or in power saver it has no problem.
After opening the program you can switch to high performance.
Only if you open the program in high performance the data panel shows black.
That's an interesting observation. Can you tell us what your current graphics driver setting is in Fusion (User menu > Preferences)?
By default this is set to "Auto-select". If Windows, see if setting it to DX11 helps. On a Mac, try OpenGL.
I would suggest you take a look at the power settings on your system. The behaviors you are experiencing are not normal operation and it may be a power setting somewhere is not what it should be.
From the behavior I wonder if the "low power" state of being unplugged kicks the card into a different mode reducing high performance features. And it's these high powered features that have issues with Fusion's Data Panel display?
BTW: Is this the internal Intel display driver or an additional card?
