Announcements
cylinder creation using construction line as axis
wadeJ4J2S
wadeJ4J2S
I'm a noob at this, but I did search for the answer...
I am trying to create a static model of a tripod with tapered cylindrical legs.  I started by creating a tetrahedron of construction lines, thinking that I would create cylinders on the 3 non-base edges, but cannot figure out how to either a) create the cylinder using a construction line as its axis, or b) create a cylinder and then reorient it to the tetrahedron edge.
Any help would be much appreciated!
Replies (7)
g-andresen
please share the file and show a picture of such an object
günther
HughesTooling
The primitives in Fusion do not work well and should be avoided in a parametric design. You are better off creating a component with a sketch and revolve then position the component on the tripod with a joint.
The leg component should look something like this. see attached file. You can then create a pattern for the other legs.
Mark Hughes
Owner, Hughes Tooling
jeff_strater
when you say "construction line" are  you talking about a Construction Axis (AKA "Work Axis"):
or a sketch construction line:
Jeff Strater
Engineering Director
HughesTooling
@wadeJ4J2S  You might find this tutorial helpful on assemblies. Shows how to add joint to a tripod from Basic Training examples.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-DE65A081-8233-456E-A930-F0D5FEB94277
Mark
Mark Hughes
wadeJ4J2S
I used construction lines to create wire-frame of a tetrahedron so that I'd know where to put the axes of the legs.
HughesTooling
You could use plane at angle to create a construction plane aligned with one of the edges to create your sketch on.
Mark Hughes
HughesTooling
Another easy way is use your wire frame with a Pipe feature. Note Pipe will not let you select construction type curves.
Mark Hughes
