Good Afternoon All,
I have a large lofted flange made up from 3/8" Plate steel, set to be formed with a pressbrake, however I need to get flat patterns made so the object can be cut out on a CNC plasma table. I cannot get a flat pattern to generate, even though I have created a cut in the lofted object so its not continuous. I would appreciate if someone could look at my file and correct it or get me .dxf flat patterns. Please see attached F3D file. Thanks!
I have not looked at the file, but did you use the sheet metal Lofted Flange or did you use solid or surface Loft?
@matt.hansen wrote:even though I have created a cut in the lofted object so its not continuous.
Does your rip go all the way through the flange?
Why does Sketch 3 repeat the hole diameter dimension 7 times?
Is the sketch fully defined?
Why does Transition component Sketch1 repeat circle diameter 7 times?
Would a Rectangular Pattern or Equal (=) constraints be more efficient for editing?
I think I would trim Sketch1 and 2 such that the Rip is created in the process of creating the Lofted Flange.
Im impressed you were able to get it flat? do you have a design recommendation?
@TheCADWhisperer could you send me that flat pattern with the issues? I still can't even get mine to unfold LOL
