Three times in the last two days I've worked on a design for an hour or so then saved it. It appears to have saved so I take a break and later return to find an error report message. On sending the report, Fusion closes and when reopened, the file saved no longer exists.
Other than saving a file before doing any work on it, is there any way to avoid this? I'm hoping there's something else I can do as Fusion has crashed when saving on Quit a couple of times recently, losing more work.
Hi @Anonymous
Thanks for reaching out to us on the forums!
If you are working on developing your connected work all your project time on the internet it is very likely that you can find a recent version of your project saved in your account at autodesk360.com
I would recommend you make a fuss over there.
Hope this helps you in your activities!
Greetings!
Did you find this reply helpful ? If so please use the Accept as Solution or LIKES button below.
Si esta respuesta te ha servido de ayuda, por favor márcala como Solución Aceptada o dale a LIKES
Hi @Anonymous
Greetings!
