I have no idea why there is nothing about this in all internet, I can not be the only one who wants to copy a body to another project, this must be easier than I think but the threads are always taking another direction.
Solved by HughesTooling. Go to Solution.
Do you want to just copy with no link to the original? If so open the design with the body you want to copy, select the body in the browser, right click and copy. Then switch to the other design, create a base feature and with it active right click and past.
If you need a link back to the original then no there is no way to do that with a standard hub. If you have a team hub copying components\bodies between projects is possible using derive.
Mark
Mark Hughes
Owner, Hughes Tooling
Hi HughesTooling, I select the body and right click to copy, when I go to the other design I can not find the "Past" option what do you mean create a base? I don't understand sorry... 😞
On the Create menu there is a option Create Base Feature, in a base feature you are basically in a no history environment and paste is available.
Mark
Mark Hughes
