Fusion Support
Report issues, bugs, and or unexpected behaviors youโ€™re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Converting SKP to DWG
5 REPLIES 5
282 Views, 5 Replies
Hi.
I downloaded a skp file from 3D Warehouse, opened it with Fusion 360 and saved it as dwg file, but when I open the dwg file there is nothing there (and the file is not that heavy).
I've done this before and everything went well, now I don't know what's going on.
Hope you can help me. ๐Ÿ™‚
5 REPLIES 5
MoshiurRashid
Hello
Thank you for posting. I think the 2d elements are not correctly saved as dwg. Can you share the skp file so that I can share the correct way to create dwg from it?
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
in reply to: MoshiurRashid
Hi Moshiur Rashid.
Attached is the skp file.
Thank you so much for your help. ๐Ÿ™‚
Have a nice day.
Mvh,
Susana Vieira
MoshiurRashid
Cant see the attached file. If you face problem attaching it. Email that file.
zamy4lead@gmail.com
Moshiur Rashid
ACP | CSWE
LINKEDIN | FACEBOOK
HughesTooling
@Anonymous  If you replied by email, attachments are stripped. You need to reply on the website if you want to attach files. You might need to ZIP the file as only a few file types are allowed as attachments.
Mark
Mark Hughes
Owner, Hughes Tooling
in reply to: HughesTooling
@HughesToolingI noticed that. Thank you so much for your reply. ๐Ÿ™‚
Have a nice day. ๐Ÿ™‚
Best Regards,
Susana Vieira
