hello,
I want to use my fusion models in unreal engine. As unreal engine accepts .FBX models (meshes). Hence i needed to know how to convert Fusion files into .FBX files.
Solved by HughesTooling. Go to Solution.
If you open the file in the online dashboard there are more export options including FBX.
Mark Hughes
Owner, Hughes Tooling
