Construction line and the "Color sketch based on constraint status"
I normally use the "Color sketch geometry based on constraint status" preview option.
This worked fine until the latest updates and was showing construction lines as interrupted brown lines.
After the last 2 updates or so, if the "Color sketch geometry based on constraint status" is turned off, the fully constrained construction lines appear as continuous brown lines instead of interrupted lines.
The problem is that if the "Color sketch geometry based on constraint status" is turned on and the construction lines are fully constrained, they appear as regular lines (black continuous lines) and there is no way of telling them apart from the normal lines.
Please fix this so that construction lines appear differently than normal lines when the "Color sketch geometry based on constraint status" preview option is enabled. I preferred construction lines as interrupted lines with another color but any other way of making them different from normal lines would suffice.
