Let me start out addressing your Screencast issue. A lot of posters have an issue using the Paste a Screencast URL command and some have issues using the HTML command in the tools menu above (which I use). I would recommend copying the Screencast URL link and using the Link command above, seventh icon from the left on the top line, to just add a link to your post. I would also leave it in Screencast format since it has a lot of advantages over an MP4.
Addressing the issue you brought up in this post, this is normal behavior of some sketch constraints such as Coincident, they only show up if you are editing the sketch and you hover over key points containing the Coincident sketch constraints. A lot of the other sketch constraints remain visible, as long as you are editing the sketch.
John Hackney, Retired
