Hello
When I have attached a Configured Design, the following error message comes up
Does anyone have an explanation for this?
Mfg
Christoph
Solved by karina.harper. Go to Solution.
Solved by a.laasW8M6T. Go to Solution.
Its not just Configured designs its any .f3z file
seems the forums are having a lot of problems lately, notifications not working, load times on pages are extremely slow.
Hey @Christoph_360 @a.laasW8M6T
This has been a problem for a while. You can either use a shared link or you can zip the file and attach it as a .zip.
Cheers,
Karina
Hello
@gautham_kattethota wrote:Testing if this is an intermittent problem
Do you mean me, i attached your Test F3Z.f3z, but it doesn't work
Mfg
Christoph
No @Christoph_360 we were just testing if this is a generic problem uploading f3z files. I should have removed the attachment, I will so now.
We will try to fix this issue.
Gautham
