Configuration Design properties and drawing attribute linking
Starting off I am fairly new to fusion 360, loads of experience in Solidworks though(expert level certified). Playing with Fusion 360 I have run into a bit of an issue that I can't figure out.
Some background, the company I am work for now does one thing and one thing only, piston rings. Been told there are 42,000 different variations of rings that are made, have been made, and there are more to be made. What I am working on now in fusion 360 is making this process streamlined for the engineering side so that I can change things in one place, the configuration table, and have it automatically update across the board, so model and drawings, and hopefully down the road I can integrate the CAM aspect too, think drill size correlated to configured diameter, maybe even update speeds and feeds based of material if possible?
Now for what i am trying to add/figure out. One of our current projects has 77 different configurations. For the most part i have flushed out the dimensional changes for the configuration table, diameters, edge breaks, fillets, ring gap, etc etc. What I am trying to do now is control material. I have figured out the theme for applying the material to the different configurations but what I am trying to add now is the different material specifications so that it will add the material spec to the drawing. So for example I can get it to add 17-7 PH CRES for material to my title block. What I would like it to add in a separate cell of the title block is the material spec AMS5528. This will also correlate with title block cell that will have the material hardness, and a title block cell that correlates with the heat treat spec.
What I want to set up is a configuration column that allows me to input text for the specs in the design tree so that when I drop the model on the drawing sheet, it automatically updates the title block with the configured information, material, material spec, hardness, hardness spec etc. I know how to do this in SW but have hit a wall in fusion 360.
